  3. Message with timeout in graphic editor (layout, schematic...
  • Views 16792
Message with timeout in graphic editor (layout, schematic)
patschouly
patschouly over 6 years ago
I have some keybindings for changing layers, grid etc. in layout and schematic. I would like to get some visual feedback what setting I switched to (for instance the grid spacing). I tried to do this with hiDisplayAppDBox, but this creates a dialog that I have to dismiss, which is a nuisance. Is there a way to draw directly on the canvas (e.g. as the "Selection Hint" does)? This message should disappear after some seconds or after the canvas is moved.
Here is my current approach:
procedure(SetGridSnapSpacing(snap)
    let( (cv)
        cv = hiGetCurrentWindow()
        cv~>xSnapSpacing = snap
        cv~>ySnapSpacing = snap
        cv~>gridSpacing = snap
        cv~>gridMultiple = 5
        hiDisplayAppDBox(?name gensym("dummy") ?dboxText sprintf(nil "Snap pattern changed to %g" snap) ?buttonLayout 'Close ?dialogType hicInformationDialog)
    ) ; let
Thanks in advance, kind regards,
Patrick
  • mbracht
    mbracht over 6 years ago
    Hi Patrick,
    You might register a timer that closes the dialog after a few secs...
    (defun volatileDialog (secs dboxText )
       (let ((name gensym("dummy")))
          (hiRegTimer (sprintf nil "(hiDBoxOK %s )" (symbolToString name)) secs*10)
          hiDisplayAppDBox(
             ?name name
             ?dboxText dboxText
    ...and then call it like this:
    (volatileDialog 1 sprintf(nil "Snap pattern changed to %L" snap))
    cheers
    Max
  • dmay
    dmay over 6 years ago
    You could create a highlight label that appears over the layout at the current zoom location and then use the hiRegTimer to clear the highlight after a few seconds. The size of the label should be made relative to the size of the current view area so that it is visible and readable whether you are zoomed way in or way out.
    curWinCoordBox = geGetWindowBox(hiGetCurrentWindow())
    Here is an example of creating a highlight label:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVwQEAU&pageName=ArticleContent
    Derek
  • dmay
    dmay over 6 years ago in reply to dmay
    Looking at the sample code in the link, it appears to delete ALL highlight sets which may not be what you want and it also requires the bindkey press. Max gave an example of hiRegTimer which could clear the highlight automatically.
    The code creates a hilightSet called set1. I'd do it like this:
    CCSaddHighlight.hiSet = geCreateHilightSet(cv list("hilite" "drawing1")) ; Store as symbol property instead of global variable
    hiRegTimer("geDeleteHilightSet(CCSaddHighlight.hiSet)" 50)
    The rest of the code can be used as is (skip the F10 bindkey). This will clear the one highlight set after 5 seconds. Of course, if your users toggle the snap grid settings more than once in 5 seconds, you'll be creating multiple highlight sets and overwriting the setting you intend to clear. I'll leave this as an exercise for you to solve. The geDeleteAllHilightSets will indeed clear all of these and any other highlights in the cellview.
    Derek
  • patschouly
    patschouly over 6 years ago in reply to dmay
    Thanks to you both, that was very helpful!
    Here is my current solution, it works well:
        let( (cv winBox y1 y2)
            ; create label hilight
            geDeleteHilightSet(SetGridSnapSpacing.hlset) ; first, delete the old hilight
            cv = geGetEditCellView()
            winBox = hiGetViewBBox()
            y1 = cadar(winBox)
            y2 = cadadr(winBox)
            textSize = (y2 - y1) / 40
            SetGridSnapSpacing.hlset = geCreateHilightSet(cv list("hilite" "drawing1"))
            SetGridSnapSpacing.hlset->enable = t
            geAddHilightLabel(
                hiGetPoint(hiGetCurrentWindow())
                lsprintf("Grid Snap Spacing: %.3f" snap)
                "lowerLeft" "R0" "roman" textSize t nil
            ) ; geAddHilightLabel
            hiRegTimer("geDeleteHilightSet(SetGridSnapSpacing.hlset)" 5)
        ) ; let
    procedure(CycleGridSnapSpacing()
        case( gridMode
            ( 1 SetGridSnapSpacing(0.001))
            ( 2 SetGridSnapSpacing(0.01))
            ( 3 SetGridSnapSpacing(0.1))
            ( 4 SetGridSnapSpacing(1.0))
            ( 5 SetGridSnapSpacing(5.0))
            ( 6 SetGridSnapSpacing(10.0))
        gridMode = mod(gridMode 6) + 1
    I'm always deleting the old hilightset before drawing the new one. This works fine, but I'm getting the following warning, which I don't understand:
    *WARNING* (GE-2144): The parameter hl:invalid is not a hilight set Id. Provide a valid hilight set Id.
    What am I doing wrong?
    Kind regards,
    Patrick
  • dmay
    dmay over 6 years ago in reply to patschouly
    If the highlight set has already been deleted, or if it has not yet been created for the first time, then you'll get that message. You can check the highlight set before deleting it:
    when(geIsValidHilightSet(SetGridSnapSpacing.hlset)
    Derek
