  3. About display options in Layout
  • Views 16543
Muralidhar
Muralidhar over 6 years ago
I newly created my workspace. I have some problems in my layout window compared to the old database. The problems are
1) In the layout--> options --> Display Form. In this Display form I am missing some features compared to old one. Which file I need to edit to get back those..?
2) Similarly when we open layout in layout XL option based on the connectivity the nets names are visible on the nets itself (In layout only). Now I am not able to see that option to enable. Where can I find it.?
Please help me on these.
Thanks.
    You've not provided enough information. My assumption from both of these is that you're using a different version of the software - it's unlikely that for either of these that it's because of some option to enable things on the form - it's probably just that these options don't exist in some older version that you're using.
    Which IC version are you using in your new workspace? Please check Help->About and report the entire version number string reported there (and perhaps compare this with the older database workspace  you were using).
