  3. Parse rodCreatePath-type subpath lists (or any list like...
  • Views 1140
Parse rodCreatePath-type subpath lists (or any list like (?width 5 ?layer "M1"))
patschouly
patschouly over 6 years ago
I'm creating my own rodCreatePath which includes snap-to-grid for diagonal segments. I've built the basic path functions, but I'm currently stuck at how to parse the lists for offsetsubpath, enclpath and subrects.
CreatePath(pts width @key (subpaths list()))
    foreach(subpath subpaths
        CreateSinglePath(CalculateOffsetPath(pts getElem(subpath ?sep)) getElem(subpath ?width))
The question is: How can I implement getElem(). That is, how can I get the individual arguments from a list like (?width 5 ?layer "M1")
Kind regards,
Patrick
    Hi Patrick,
    How about this? It's quite simple and elegant:
    ; if this was written in SKILL++ (ils) mode, pass the environment
    ; symeval(element theEnvironment())
    procedure(getElem(subpath element)
        destructuringBind((@key layer width sep justification beginOffset
                endOffset choppable prop enclosure) subpath
            symeval(element)
    The use model would be slightly different - you'd use getElem(subpath 'width) (which would look less confusing because normally you don't have keyword arguments without a value). I made the getElem have the superset of enclosure and offset subpath arguments from rodCreatePath, but of course  you can tweak that to suit your needs.
  • patschouly
    patschouly over 6 years ago in reply to Andrew Beckett
    Awesome, that is indeed simple and elegent. Thanks for you help!
