  3. Update cyclic CDF parameters in callback
  • Views 17048
patschouly
patschouly over 6 years ago
I have a cell with several CDF parameters, where some of the cyclic fields have varying options (depending on other CDF parameters). I'm updating them within callbacks, which currently does not really work. I'm changing the choices based on a few cases, but I get a warning (*WARNING* Form 'schObjPropForm', field 'serialnum': Bad value "none" Cyclic value must be one in the list of choices.) and the pcell is not updated (I'm changing the symbol based on these parameters).
Here is the callback:
procedure(msclab_cable_callback(what)
    let(
            (cablelength (car (setof param cdfgData~>parameters param~>name == "cablelength")))
            (connector (car (setof param cdfgData~>parameters param~>name == "connector")))
            (partnum (car (setof param cdfgData~>parameters param~>name == "partnum")))
        partnum->choices = case(connector->value
            ("foo" list("123456" "98765"))
            ("bar" list("none"))
        partnum->value = case(connector->value
             ("foo"  "123456")
             ("bar" "none")
In the pcell I of course define the CDF parameters, the CDF callback is also properly triggered.
What am I doing wrong?
Kind regards,
Patrick
    Hi Patrick,
    There's a CCR for this warning - 1796076. From my quick experiments it actually works, it's just this spurious warning that's an issue. A colleague has written an article with a rather complicated workaround (not published yet because it's hard to understand) but having reviewed it, it doesn't really do what you want (and I don't think it's very useful either because of a serious limitation in the approach taken - so I won't repeat it here).
    So for now, you probably need to just live with the warning, but you could contact customer support and ask for a duplicate CCR to be filed.
