  3. custom layout function
  • Views 15396
SrBraj
SrBraj over 6 years ago
Currently, I am working on a script file. The flow is something like create a library, then create a cell, create a layout view in the cell and place the p-cell on the layout view.
While creating the library, tech library wasn't attached to the created library. To attach the tech library to my created library I am using the following skill macros:
absSetLibrary( <created library name> )
absAttachTechLib( <Tech Library Name> )
While executing the script file I am getting the following error on CIW:
*Error* eval: undefined function - absSetLibrary
What is the correct way to attach the tech library to the library I am creating?
  • Sheppie
    Sheppie over 6 years ago
    Hi SrBraj,
    Please see the following article, here you should find what you need:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXcmEAE
    Kind regards,
    Sjoerd
