  3. UI created using skill APIs
  • Subscribers 150
  • Views 15461
SrBraj
SrBraj over 6 years ago
Dear Sir/Madam
I have created an UI using the skill APIs. In this UI I have many fields including the library names and cell names.
In my UI, I want to display the cell names in the "'cellName" field from the library selected in the "libName" field. I have written the following code:
hiCreateCyclicField(
       ?name           'libName
       ?choices        sort( ddGetLibList()~>name 'alphalessp )
       ?prompt         "Library"
       ?defValue         "PRIMLIB"
       ?callback       "aquaQrc~>cellName~>choices = sort( ddGetObj(aquaQrc~>libName~>value)~>cells~>name 'alphalessp )" ; callback
       ?name           'cellName
       ;?choices        sort( ddGetObj(car(ddGetLibList()~>name))~>cells~>name 'alphalessp )  ; commented
       ?choices        sort( ddGetObj(aquaQrc~>libName~>value)~>cells~>name 'alphalessp )  ; Uncommented
       ?prompt         "CellName"
I get the below mentioned error using the above code,
*Error* eval: unbound variable - aquaQrc
Steps to reproduce the issue:
I. invoke virtuoso (all the skill files are loaded at the time of invoking the virtuoso)
ii. click menu to create UI, (The UI is enabled by menu)
but If I load the skill file again using the load command on CIW, click Menu, my UI is created and function as designed without any error. 'cellName field display the cellnames from the default "PRIMLIB" library.
If I uncomment the commented line, and comment the line below it, then I don't get any error, but 'cellName field doesn't show the cellnames from the default "PRIMLIB" library.
Seems like, formHandle aquaQrc isn't created just after the virtuoso is started.
Can you please suggest some work-around to this problem?
    Presumably it's because the form isn't created until after you create the fields (nothing to do with when virtuoso is started). Since the choices is only setting the default value (and you update the choices dynamically as the library field is updated), simply doing:
    ?choices sort( ddGetObj("PRIMLIB")~>cells~>name 'alphalessp ) ; Uncommented
    would be sufficient (i.e. populate the field based on the default library name set in the previous cyclic field).
    However, better still would be to use the dedicate fields that do this already for you - they avoid you having to write code to populate the choices. See this example.
