  3. Sorting list of Bounding boxes
  • Replies 8
  • Views 22114
Arava
Arava over 6 years ago
I wrote a custom procedure to which setof function will give sorted list (Bottom-Left to Top-Right) of bBoxes as input.
Order of the list will decide the functioning of the procedure.
Now i started working on lower nodes (virtuoso version 12.3-64b), i don't know the exact reason "setof" output is not following the order Bottom-Left to Top-Right.
Can anyone help me to get "setof" output in order or any procedure to sort the bBox list.
Any switch need to changed? or problem with virtuoso version using?.
Arava.
    Arava,
    setof doesn't sort anything (nor ever has done). There's no switch or problem with the Virtuoso version because this is not what setof is supposed to do. All setof does is return the members of a list that match a condition.
    Perhaps you should post your code so that we know what you're talking about? I could give you code to do the sorting, but given your misunderstanding about setof, I'd like to be clear about what it's expecting.
  • Arava
    I wrote a custom procedure to which setof function will give sorted list of bBoxes as input.
    Order of the list will decide the functioning of the procedure. Earlier I used to get the bBox list in proper way (BottomLeft-TopRight).
    Can anyone help me to get "setof" output in order.
    Any switch need to changed? or problem with virtuoso version which i am using?.
    Arava.
    Andrew Beckett over 6 years ago in reply to Arava
    You just posted the same question twice with a different subject line. I joined the two posts as I already answered it (see further up the thread).
  • Arava
    Arava over 6 years ago in reply to Andrew Beckett
    Thanks Andrew.
    sorry its order of shapes not bBoxes, (actually procedure works on bBox of  OUTLINEs).
    outlineLpp=list("OUTLINE" "drawing")
    outlines = setof(obj cvId~>shapes obj~>lpp == outlineLpp)
    OL_bBox=outlines~>bBox
    Arava.
    So which do you want sorted, the variable outlines or the variable OL_bBox?
  • Arava
    Finally OL_bBox must be a list of bBoxes order from BottomLeft to TopRight
    Arava
    procedure(CCFcompareBBoxes(bb1 bb2)
      let((ll1 ll2)
        ll1=lowerLeft(bb1)
        ll2=lowerLeft(bb2)
        if(xCoord(ll1)==xCoord(ll2) then
          yCoord(ll1)<yCoord(ll2)
        else
          xCoord(ll1)<xCoord(ll2)
    OL_bBox=sort(outlines~>bBox 'CCFcompareBBoxes)
    This sorts based on the lower left of the bBox, by x coordinate first, then y. If you need a different order (BottomLeft to TopRight is ambiguous in your description), then it's easy enough to change the code - the comparison function returns t if the first bounding box is "less" than the second, and you can define what you mean by "less".
  • Arava
    Thank you so much Andrew Slight smile
    This works perfectly!!!
