  3. Single Tool or App for multiple DataFormats or viewType...
  • Views 14261
Single Tool or App for multiple DataFormats or viewTypes
Curtisma
Curtisma over 5 years ago
Hello:
I am defining several DataFormats in a data.reg.  I would like to be able to use a single application to open several views with different file extensions.  When I try to assign two different dataformat with different extensions to the same application, it doesn't work.  Only the last definition listed in the data.reg (format_B in the example) shows up when I try to create a new cell view.  When I try checking deGetAppInfo with the first defintion, deGetAppInfo("format_A") below, it comes back empty, but deGetAppInfo("format_B") gives the expected result. Do I have to make a unique App/Tool for every cellview?  I would prefer one application definition since all the views, each pointing to files with different extensions, use the same callback code to start the application since the application supports multiple formats.
Also, the deRegApp documentation refers to view subtypes and says you can sobclass any number of parent types.  However I couldn't find a definition to these terms or a clear explanation of what they are.  Is that just for inheriting the callbacks from the parent viewType or is there more to it?  Would it help with this issue?
data.reg for Example:
DataFormat format_A {
Pattern = *.extA;
Preferred_Editor = exampleEditor;
Default_Editor = exampleEditor;
dfII_ViewType = format_A;
Co_Managed = master.tag data.dm *.extC;
DataFormat format_B {
Pattern = *.extB;
dfII_ViewType = format_B;
Co_Managed = master.tag data.dm;
deRegApp code for Example:
when(!member("format_A" deGetAllViewTypes())
deRegApp(
?appName "exampleEditor"
?enableTrigger 'EnableTrigger
?dataTrigger 'DataTrigger
?viewType "format_A"
?appTrigger 'ViewAppTrigger
?widgetType "graphics"
when(!member("format_B" deGetAllViewTypes())
deRegApp(
?viewType "notebook"
Tool exampleEditor {  }
Curtis
  • Curtisma
    I am using IC6.1.8-64b.500.8.  I went ahead and submitted a support request.
    Andrew Beckett over 5 years ago in reply to Curtisma
    I don't think this can be done. You can't share the same application for different data formats. Using a parent viewType doesn't help because you have to declare the triggers anyway for each application - but you can share the functions.
    It's a bit of an unusual request - so probably best followed up via your support request (which was the best thing to do anyway for this question). Unfortunately I'd spent time looking at it and experimenting before I saw that you'd edited your post to say that you'd submitted a support request (I wouldn't have done otherwise as duplicating the work of a colleague doesn't make sense either for me or them).
