  3. How to show/hide multiple fields in a form?
  • Views 3943
Quesar
Quesar over 6 years ago
In the Virtuoso XStream Out GUI for example, the Layer Map, Object Map, and Log File sections are user-clickable expandable/collapsible sections which show/hide multiple form fields. I'd like to know how to do this, or which function(s) are responsible for this behaviour.
I have checked the documentation but I could not find any clues there.
Any help would be appreciated. Thanks.
    That UI isn't actually implemented in SKILL, but the same capability is available using "progressive disclosure" widgets - in particular the hiCreateDisclosureTriangle function (there's also the similar hiCreateDisclosureButton too). An example of using these (as well as all other hi fields) can be found in this excellent article by one of my colleagues: Worked example using all available SKILL UI fields (they're on the third tab).
    If these are used together with the "layout forms" (hiCreateLayoutForm etc) then the space also collapses. I threw together a simple example shown below:
    *                   CCFcreateExampleLayForm()                  *
    *               You guessed it. Creates the form               *
    procedure(CCFcreateExampleLayForm()
        let((field1Label field1Entry field2Label field2Entry extraParams
            paramLabel minLabel stepLabel maxLabel
            paramEntry minEntry stepEntry maxEntry
            gridLayout)
            field1Label=hiCreateLabel(
                ?name 'field1Label
                ?labelText "First Field"
                ?justification 'right
            field1Entry=hiCreateStringField(
                ?name 'field1Entry
            field2Label=hiCreateLabel(
                ?name 'field2Label
                ?labelText "Second Field"
            field2Entry=hiCreateStringField(
                ?name 'field2Entry
            extraParams=hiCreateDisclosureTriangle(
                ?name 'extraParams
                ?labelText "Extra Parameters"
                ?onFields
                    list(
                        'paramLabel 'minLabel 'stepLabel 'maxLabel
                        'paramEntry 'minEntry 'stepEntry 'maxEntry
            paramLabel=hiCreateLabel(
                ?name 'paramLabel
                ?labelText "<b>Parameter</b>"
            minLabel=hiCreateLabel(
                ?name 'minLabel
                ?labelText "<b>Minimum</b>"
            stepLabel=hiCreateLabel(
                ?name 'stepLabel
                ?labelText "<b>Step</b>"
            maxLabel=hiCreateLabel(
                ?name 'maxLabel
                ?labelText "<b>Maximum</b>"
            paramEntry=hiCreateStringField(
                ?name 'paramEntry
            minEntry=hiCreateStringField(
                ?name 'minEntry
            stepEntry=hiCreateStringField(
                ?name 'stepEntry
            maxEntry=hiCreateStringField(
                ?name 'maxEntry
            gridLayout=hiCreateGridLayout(
                'gridLayout
                ?items list(
                    list(field1Label 'horiz_align 'right 'row 0 'col 0)
                    list(field1Entry 'horiz_align 'right 'row 0 'col 1 'col_span -1)
                    list(extraParams 'horiz_align 'left 'row 1 'col 0)
                    list(paramLabel 'horiz_align 'left 'row 2 'col 0)
                    list(minLabel 'horiz_align 'left 'row 2 'col 1)
                    list(stepLabel 'horiz_align 'left 'row 2 'col 2)
                    list(maxLabel 'horiz_align 'left 'row 2 'col 3)
                    list(paramEntry 'horiz_align 'left 'row 3 'col 0)
                    list(minEntry 'horiz_align 'left 'row 3 'col 1)
                    list(stepEntry 'horiz_align 'left 'row 3 'col 2)
                    list(maxEntry 'horiz_align 'left 'row 3 'col 3)
                    list(field2Label 'horiz_align 'right 'row 4 'col 0)
                    list(field2Entry 'horiz_align 'right 'row 4 'col 1 'col_span -1)
                    list('col_stretch 0 1)
                    list('col_stretch 1 1)
                    list('col_stretch 2 1)
                    list('col_stretch 3 1)
            hiCreateLayoutForm(
                'CCFexampleLayForm
                "Example Form"
                ; Surrounding vertical box layout is to have a stretchable
                ; item below the layout to absorb all the stretchiness!
                hiCreateVerticalBoxLayout(
                    'vbox
                    ?items list(
                        gridLayout
                        list('stretch_item 1)
            CCFexampleLayForm
    *                  CCFdisplayExampleLayForm()                  *
    *           Create (if needed) and display the form            *
    procedure(CCFdisplayExampleLayForm()
        unless(boundp('CCFexampleLayForm)
        hiDisplayForm(CCFexampleLayForm)
  • Quesar
    Quesar over 6 years ago in reply to Andrew Beckett
    Thanks Andrew! I will take a close look at the link you posted as well as your example above. As always, you're this forum's saviour  Smiley
