  3. How to get absolute path of file/dir with Custom IC Ski...
  • Replies 12
  • Subscribers 152
  • Views 13835
How to get absolute path of file/dir with Custom IC Skill
Phuong Truong
Phuong Truong over 6 years ago
Hi all,
I am beginner for Skill language. Please help to clarify that how to get absolute path of file/dir with Custom IC Skill.
Thank you.
Best Regards,
Phuong Truong
    I'm not entirely sure what you're asking for, but it's probably simplifyFilename. For example, simplifyFilename("./localFile") will convert it too the full path.
  • Phuong Truong
    Phuong Truong over 6 years ago in reply to Andrew Beckett
    Thanks for your reply.
    In my question, I want to ask that how to get absolute path of file/dir with Custom IC Skill. And file/dir is any included ( localFile, external file,...)
    Example:
    Enter: ./filename.il
    Result: /parentA/parentB/parentC/../filename.il
    Andrew Beckett over 6 years ago in reply to Phuong Truong
    Not sure what you mean by "localFile" "external file" but did you actually try using simplifyFilename? That will give the full path for a local file or directory.
  • Phuong Truong
    Yes, I tried to use simplifyFileName but the result is not my expectation. Actually, simplifyFilename(./filename) will return "/current_path/filename".
    But I want to return the absolute of filename ( filename here is in other direction, not in current direction).
    Please help me to clarify.
    Thank you.
    I have no idea what you're talking about. What is "absolute of filename" or "filename here is in other direction, not in current direction"? What does the "direction" of a file mean? (files don't have directions - so I'm a bit mystified as to what you're asking).
    Perhaps you can give a detailed example - explaining where the file actually is on the file system, and what your working directory is, and what  you are expecting to pass to the function (assuming there is a function) and what you're expecting it to return.
  • Phuong Truong
    Yes.
    Below are detailed information of example:
    My working directory is "/proj/cad/users/phuongtruong/skill_cadence/run_tools/virtuoso"
    File which need to get absolute path : absolute_path.il in directory "/proj/cad/users/phuongtruong/skill_cadence/sample/"
    ==> I need to get absolute path of file "absolute_path.il"
    Isn't that just going to be:
    dir="/proj/cad/users/phuongtruong/skill_cadence/sample"
    file="absolute_path.il"
    fullPath=strcat(dir "/" file)
    Or if you want to resolve links etc, then it would be:
    simplyFilename(strcat(dir "/" file))
    I must be missing something here, because this seems pretty obvious - so I'm guessing you're really trying to ask something else.
  • Phuong Truong
    The expected result is "/proj/cad/users/phuongtruong/skill_cadence/sample/absolute_path.il"
    That's exactly what the strcat in my previous post gives. So is that what you want?
  • quyleanh
    quyleanh over 6 years ago
    Use simplifyFilename function
    Example: simplifyFilename( "cds.lib" ) => "ful/path/to/your/cds.lib"
