  3. Turning a bus path corner with 90 degree to 45 degree
  • Views 17683
Will Tang
Will Tang over 6 years ago
Hi all,
For examples, I create a bus of path with 90 degree turning like a "L" shape.
How can I modify this path corner from 90 degree to 45 degree, without converting the path to polygon?
Any help is much appreciated.
Thank you very much !!
Will
    Andrew Beckett over 6 years ago +1
    Assuming that the bus was created using Create->Wiring->Bus (i.e. was created as wires using path segments rather than paths) then you can use Edit->Wiring->Wire to 45 (this is a VLS XL feature rather…
    Assuming that the bus was created using Create->Wiring->Bus (i.e. was created as wires using path segments rather than paths) then you can use Edit->Wiring->Wire to 45 (this is a VLS XL feature rather than VLS L). This does exactly what you want...
  • Will Tang
    Will Tang over 6 years ago in reply to Andrew Beckett
    Thank you very much for your support.
    That is exactly what I want.
