  3. Searching and Extracting LPPs from the techfile with a ...
  • Views 18165
Searching and Extracting LPPs from the techfile with a condition
blankman
blankman over 6 years ago
I would like to extract a list of LPPs from my techfile that have the word "fill" in any part of of the purpose description, ie for example (RX cfill) (RX gapFill) (RX fillOPC). I would like all of these LPPS to be listed, and irrespective of case. Could anyone help me with how to obtain this list of LPPs?
Brian.
  • skillUser
    skillUser over 6 years ago
    Hi Brian,
    The following returns the LP objects that match from the tech file (assuming a current cellview for obtaining the technology file):
    setof(lp techGetTechFile(geGetEditCellView())~>lps rexMatchp("[fF][iI][lL][lL]" lp~>purpose))
    The LP object is a particular representation of a layer-purpose pair - using the object you can access the layer name: LPobj~>layer~>name, and was you can see above you can access the purpose directly.
    Hope this helps!
    Lawrence.
  • blankman
    blankman over 6 years ago in reply to skillUser
    Thanks Lawrence,
    Andrew Beckett over 6 years ago in reply to blankman
    Hi Brian,
    LPobjectsFinal=foreach(mapcar lpp LPobjects list(lpp~>layerName lpp~>purpose))
    will do it.
  • skillUser
    skillUser over 6 years ago in reply to Andrew Beckett
    Minor correction:
    LPobjectsFinal=foreach(mapcar lpp LPobjects list(lpp~>name lpp~>purpose))
    since these are 'LP' objects (~>layerName will return 'nil')
    Best regards,
    Lawrence.
    Andrew Beckett over 6 years ago in reply to skillUser
    Thanks Lawrence. The perils of writing a reply on the phone without testing it or checking!
  • blankman
    blankman over 6 years ago in reply to Andrew Beckett
    Thanks Lads! That is much appreciated, Brian.
