  3. passing variable for plot expression in plot() COMMAND
  • Subscribers 150
  • Views 16568
RFStuff
RFStuff over 6 years ago
Dear All,
I want to pass  a variable for wave expression in plot() .
The below command gives the wave name as waveName
plot(drCreateWaveform(drCreateVec('double xList) drCreateVec('double yList)) ?expr '("waveName") )
If I want to pass a variable to ?expr '(" "), how it can be done ?
Kind Regards,
    Use list() rather than '(). So:
    waveName="RFStuff"
    plot(drCreateWaveform(drCreateVec('double xList) drCreateVec('double yList)) ?expr list(waveName))
    The quote function prevents its arguments from being evaluated, so you just need to use list instead (which will evaluate all of its arguments, like most functions do).
  • RFStuff
    RFStuff over 6 years ago in reply to Andrew Beckett
    Thanks Andrew.
    Suppose my list  is MY_LIST=list("RFStuff" "Andrew")
    In first iteration of plot (in a for loop say)  it should be passed as "RFStuff".
    In the second iteration  it should be passed as "Andrew".
    How this can be achieved here ?
    Andrew Beckett over 6 years ago in reply to RFStuff
    foreach(waveName MY_LIST
      plot(... ?expr list(waveName))
    would do what you want. Maybe you want something like this?
    xData=list(
      list(1 2 3)
      list(1 2.4 4 5.6)
    yData=list(
      list(2.0 1.4 5.2)
      list(-1.2 3.4 8.7 7.2)
    MY_LIST=list("RFstuff" "Andrew")
    foreach((xList yList waveName) xData yData MY_LIST
  • RFStuff
    Thanks a lot Andrew.
