  3. Copy synchronous clones between layout views
  • Views 18113
DanielDing
DanielDing over 6 years ago
Greetings!
After some search on the topic, I decided to start a new post for this question. Much appreciate your help in advance.
I notice when using leHiCopy() to copy clone groups from one layout view to another layout view, the synchronous information is lost..
Is there a way to preserve such info?
If not, I was about to save the info first, then reconstruct it after the copy happens, assuming predictability in how Virtuoso renames figure groups.
Duo
    Andrew Beckett over 6 years ago +1
    Duo, You may want to take a look at this: How to generate a clone structure from another cellview in a different library Regards, Andrew.
    Duo,
  • DanielDing
    DanielDing over 6 years ago in reply to Andrew Beckett
    Much appreciate it, Andrew! The above forwarded post indeed helps simplify my workaround scripts.
    Cheers,
    Duo
