  3. How to get the properties like width, number of legs of...
  • Views 16435
How to get the properties like width, number of legs of an instance present in a schematic
basucs011
basucs011 over 6 years ago
Hi..
I want to know the properties of an schematic instance when we query the instance using skill.
For example width of the instance or number of legs or name of the instance.
I am opening the schematic by its library,and cell name in schematic view in db mode
test = dbOpenCellViewByType("library" "cellname" "view")
test~>instances
by this i am getting dbids of all instances.
so what to do next to get select each instance and get the properties of that
Thanks in advance for the solution
  • mbracht
    mbracht over 6 years ago
    To select all instances you do:
    (geSelectFigs test~>instances)
    To print the properties (assuming you talk about user defined properties which I guess you do):
    (foreach inst (geGetWindowCellView)~>instances
        (println inst~>name)
        (foreach prop inst~>prop
            (printf "\t%L %L\n" prop~>name prop~>value))) t
