  3. IC1616 Custom Toolbar Icons That Change on State
  • Views 15719
mrharris
mrharris over 6 years ago
I would like to add a toolbar icon that when selected toggles gravity on and off. I have this working through the customization form. As an enhancement I would like the ICON to indicate if gravity is enabled or not instead of looking at the log window to determine this. How would one write a callback such that it updates the icon used based on the state of whether gravity is enabled or not?
Micky Harris
    Hi Micky,
    If you mark the Action as "checkable" then it will automatically toggle the icon each time you press it. Does that do what you want?
  • mrharris
    mrharris over 6 years ago in reply to Andrew Beckett
    That will gray it out vs not, similar to a press button. I was curious if there was a way to have the icon change similar to the partial vs full selection and entry mode. For example a black G for off and a green G for on.
    Micky
    Andrew Beckett over 6 years ago in reply to mrharris
    Micky,
    In the callback for your toolbar action, you would need to do something like this (this is not the code for the partial/full-selection icon, but it's similar to this idea):
    let((win swin optionToolbar action)
      win=hiGetCurrentWindow()
      swin=hiGetSessionWindow(win)
      optionToolbar=car(exists(toolbar hiGetWindowToolbars(swin) hiGetToolbarObjName(toolbar)=="Options"))
      action=optionToolbar->lebSelect
      ; would normally check win~>partialSelect but since changing that
      ; has a trigger to change the icon, show the principle by using a global variable that you can set to try this out
      if(boundp('PARTIAL_SELECT) && PARTIAL_SELECT then
        action->hiIcon="vertex-select-partial.png"
        action->hiToolTip="Partial Select"
      else
        action->hiIcon="vertex-select-full.png"
        action->hiToolTip="Full Select"
    Hope that helps!
