  3. Post Run Simulation Analysis - Plotting wavefroms from different...
  • Views 1480
Post Run Simulation Analysis - Plotting wavefroms from different tests
Esteban Jose
Esteban Jose over 6 years ago
Hi all,
I have my ocean script where I execute two different tests as following:
Then from CIW I execute the following commands in order to plot the waveforms:
in_sig=v("/I0/SN" ?result `tran)
awvPlotWaveform(newWindow() list(in_sig) ?expr list("SN" ) )
But.. this only plot the results from one test. Is it possible, with a SKILL command,  select which test to plot? or simply plot all the tests?
Best,
EJ
    Andrew Beckett over 6 years ago +1
    You need to use openResults() to open the results for each test (or the specific test you’re interested in). Otherwise it won’t know which test you’re trying to plot from. So something like: sess=axlGetWindowSession…
    sess=axlGetWindowSession()
    sdb=axlGetMainSetupDB(sess)
    hist=axlGetCurrentHistory(sess)
    ckpt=axlGetHistoryCheckpoint(hist)
    resultsRoot=axlGetHistoryResultsDir(axlGetCurrentHistory(sess))
    foreach(testName cadr(axlGetTests(ckpt))
    resultsDir=strcat(resultsRoot “/psf/“ testName)
    openResults(resultsDir)
    ; now you can do your plotting
  • Esteban Jose
    Esteban Jose over 6 years ago in reply to Andrew Beckett
    Thank you Andrew!
    best,
    EJ
