  3. How to use one corner output expression in other corners...
  • Views 5128
How to use one corner output expression in other corners for a multiple corner/sweep sim?
oyayla
oyayla over 5 years ago
Hi all,
I have a simulation testbench in ADEXL which has multiple corners to run. I want to use one of corner output expression in other runs.
To give couple example for usage: I will run ss, ff and tt corners in the same simulation in parallel and scale all output currents to tt value. Or I will run schematic based netlist and dspf based post-simulation netlist in parallel. Then, I want to compare the output expression between these two for verification. This can be scalable to over PVT as well.
I am not sure if this is possible in the same simulation since simulation finish time can be different. I am open to other ways to do these as well.
yayla
Version Info:
ICADV12.3 64b 500.21
spectre -W =>
Tool 'cadenceMMSIM' Current project version '16.10.479'
sub-version  16.1.0.479.isr9
    I’m not entirely certain how your simulations are set up, but it sounds as if you need to use the calcVal function to retrieve the output from a particular test and then use it in other tests:
    calcVal(“myOutput” “myTest” ?cornerName “tt”)
    This would be the value of a global variable. I would anticipate that you would have one test where you only have the tt corner enabled, and that the global variable is disabled for that test and the local (design) variable used. Then the second test would have all the other corners enabled and use this calcVal expression from the first to retrieve the nominal measurement and use it to do your scaling
    Something like that.
  • oyayla
    oyayla over 5 years ago in reply to Andrew Beckett
    Thanks Andrew. You suggest using two different testbench and forcing the 2nd which has the multiple runs to wait 1st run(normalized one in my example). I was trying to make in a single simulation not to maintain to testbenches but if there is not other way, I will try to do this calcVal method.
    Mustafa
