  3. ymax doesn't apply to AC waveforms?
  • Views 2292
monglebest
monglebest over 6 years ago
I am using 6.1.8-64b.500.9.
I ran a AC and transient and when I applied ymax(IT("/ITX_CCII_buf/ccii_inp")), I get a result. but when I applied ymax(IF("/ITX_CCII_buf/ccii_inp")),
ERROR (VIVA-3002):expression evaluation failed: Expression evaluates to nil
ERROR (VIVA-3002):expression evaluation failed: ymax(IF("/ITX_CCII_buf/ccii_inp"))
Why ymax() cannot work on IF or VF results, if I want to find the AC response peak, what function should I use?
Regards
monglebest
    Andrew Beckett over 6 years ago +1
    That's because IF and VF produce complex waveforms. When you plot them it automatically plots the mag() of a complex waveform, so to find the ymax use: ymax(mag(IF("/ITX_CCII_buf/ccii_inp"))) Regards…
  • monglebest
    monglebest over 6 years ago in reply to Andrew Beckett
    Thanks, I didn't realize the answer is so simple.
