  3. Virtuoso XL Calculator Multiple Expressions
  • Views 16685
hikmetceliker
hikmetceliker over 6 years ago
Hello all,
I have a combinatorial circuit with 8-bits of input and output buses and I am trying to find the delay between two buses. My main goal is to find the critical path of my custom designed digital circuit. If I use calculator for finding the delay of separate bits (from 0 to 0 in this case), I use this expression and it works:
delayMeasure(leafValue(VT("/in<7:0>") "bit" "/in<0>" ) leafValue(VT("/out<7:0>") "bit" "/out<0>" ) )
However, I could not find a way to calculate multiple expressions at once as I need to do that for 64 different combinations. If I write two expressions following each other as below, it calculates only the first expression. Am I doing a syntax error or is it not possible to calculate multiple expressions in the calculator?
delayMeasure(leafValue(VT("/in<7:0>") "bit" "/in<0>" ) leafValue(VT("/out<7:0>") "bit" "/out<1>" ) )
Thank you for all replies in advance.
Hikmet
