  3. Skill Code to set the pitch between edges of two Rectan...
  • Views 16347
Skill Code to set the pitch between edges of two Rectangles
anode
anode over 6 years ago
I have created two rectangles using RodCreateRect( in the same layer .
How do I set the distance between from one edge to another edge using skill command.
Many Thanks
Hosein
    Hi Hosein,
    You can use rodAlign to do this. Simply give the align and reference objects, the handles for each edge, and then ?xSep or ?ySep to specify the distance (in whichever direction you want the gap to be).
  • anode
    anode over 6 years ago in reply to Andrew Beckett
    Thanks Andrew
