  3. Insert variable in CIW.
  • Views 17898
denis1235
denis1235 over 6 years ago
Hi, All!
I'm a new SKILL developer, and i have one question.
Does Skill have a command for inserting data in CIW, similarly in C++, with command "cin>>"?
Or I should just assign value of variable manually, as Variable = "Value"?
Best Regards,
Denis.
  • mbracht
    mbracht over 6 years ago +1
    Hi Denis, To read from standard in you do (gets result piport) ...with whatever you type going to result. So that'd be the equivalent of cin>> in C++. However I don't understand what that's got to do…
  • mbracht
    mbracht over 6 years ago in reply to denis1235 +1
    Denis, Both << as well as >> are overloaded operators in C++ which is a concept that is neither supported in SKILL nor in SKILL++ (at least as far as I know...). So the gets() solution I gave you earlier…
  • mbracht
    Hi Denis,
    ...with whatever you type going to result. So that'd be the equivalent of cin>> in C++. However I don't understand what that's got to do with assigning a value to a variable, I mean you just type the variable and it's value into the CIW and that's it.
    Max
  • denis1235
    denis1235 over 6 years ago in reply to mbracht
    I mean that in C++, if I want to assign a value of variable, i write:
    cout<<"Value of this variable:";
    cin>>var;
    And until I insert this value, terminal will wait this. Does SKILL have such analog? Or I can insert value just Variable = "value"?
    Denis
  • mbracht
    Can you please explain why you want to do this. Why not just type
    variable=value
    You need to explain the use case. Why buffer a value in a stream and then in a second step read from that stream?
    Max
  • denis1235
    Below, I attached part of my script, with it I set a new values of CellType and SiteDefinition. I did it, but for inserting new values, need uncomment few strings and enter new values instead value in quotes, as *VAR", or *SITE_NAME* and so on. And my colleague want insert new values from CIW. And I tried make it with standard type in CIW, but for her it looks like not comfortable. So I tried do it with equivalent in C++.
    My realization:
    ;IF YOU WANT TO CHANGE SITE DEFINITION, UNCOMMENT 2 NEXT STRING AND TO SET VARS:(*SITE_NAME*),(*SITE_ORIGIN*),(*SITE_ROTATE*) TO REQUIRED VALUES
    ;SiteDefinition = '(("*SITE_NAME*" (*SITE_ORIGIN*) "*SITE_ROTATE*"))
    SITE = window~>topCellView->sitePattern=SiteDefinition
    ;FOR SETTING NEW VALUE FOR -CLASS-, UNCOMMENT NEXT STRING AND WRITE NEW NAME INSTEAD *VAR*
    ;window~>topCellView->cellType = "*VAR*"
    Denis
  • mbracht
    Denis,
    So the gets() solution I gave you earlier is getting closest to what you want. However this is a rather unusual way in virtuoso so I strongly recommend to read the variable value through a form.
    regards
    Max
  • denis1235
    Thx you, Max!
    I'm glad for your help!
    Kind regards,
    Denis
