  3. running skill script from Unix command line
  • Subscribers 150
  • Views 18245
SrBraj
SrBraj over 6 years ago
Hello Support Team
I have written a skill script file to automatically run the QRC(LVS+QRC). The flow of this script is as mentioned below:
i: This script adds a menu "ABC" in the CIW
ii. Clicking this menu will open a GUI(coded in skill).
iii. The user would need to enter some information in the GUI.
iv. Click the Ok button, the script will start QRC run.
I have tested this flow and it is working perfectly fine.
Now I want to run the same script using the Unix command line. Could you please tell me if there is a way to enter GUI information through the command line.
Thanks and Regards
Saurabh
    Hi Saurabh,
    Ideally you'd structure your code so that you have a separate procedural interface (a function that accepts all the data it needs as arguments), and then submits the QRC run based on that. Then the form callbacks call this procedural function with the arguments populated from data you've entered on the form. This is good practice (I mention this in my "Writing Good SKILL Code" video which is on http://support.cadence.com
    That would then make it much easier to run from the command line - otherwise you end up havng to mess around with seeding a form (in nograph mode) from the command line - which is an unnecessary complexity if you've written the code yourself.
    If you do this, then you could write a shell script to take the arguments passed to the script, create a temporary SKILL file which loads the code, calls the function with the arguments as passed into the script, and then runs "virtuoso -nograph -restore tempScript.il" (or whatever you've called it) to run the job.
    Pretty straightforward...
