  3. How to Execute Unix Commands through CIW Window and Store...
  • Replies 21
  • Views 17630
How to Execute Unix Commands through CIW Window and Store the output in a variable on Unix/CIW Window (Rather than file)?
Sonu Chopra
Sonu Chopra over 6 years ago
Hello Support,
I have one query regrading the Execution of Unix Commands through CIW Window. Currently i am using system or sh/shell Command and i am storing the output in a file . Can there be a way that We Can Store the output in a variable itself (Accessible form Unix/CIW Window).
The Query is that i want to have the layer Map File Path and I want to store it to a variable (Don't want output  to redirect to file and i don't want to read the file to get the path in a variable if possible)
; Getting the LayerMapFile Path and Storing in a file
system("piGetInfo $DKITROOT lyrFilIn  >layermapfile.il")
Above Command is working Fine and layermapfile.il is containing the LayerMapFile Path
;Getting the LayerMapFile Path and Storing in a Variable
system("setenv layerMapFile `piGetInfo $DKITROOT lyrFilIn` ")
Above Command is throwing a error :- sh: setenv: command not found
Can you please provide some help on this?
Thanks in Advance,
Regards
Sonu
    Andrew Beckett over 6 years ago +1
    Hi Sonu, There are several things wrong here. First of all, "setenv" is a csh not sh command, and so it's not surprising that gives an error. Even if you'd used csh() instead of sh(), it wouldn't have…
  • mbracht
    mbracht over 6 years ago in reply to Sonu Chopra +1
    Hi Andrew, I think the idea is to repopulate the combo box each time you type something into the text field. So assume you start wit a list '("abc" "def" "auv") and then type 'a' into the text filed…
    Andrew Beckett over 6 years ago in reply to Sonu Chopra +1
    With my code there is no problem with deleting what you've typed in and then typing something else. It keeps the complete list of choices and updates starting from the complete set each time you type.…
    Andrew Beckett over 6 years ago in reply to mbracht
    Max,
    This code (assuming I can paste it in - it's causing trouble) works. I used substring and setof rather than pcreMatchList as it's not really a regexp:
    I can't paste the code or add as an attachment. I'll speak to IT.
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    If I understand it well then you have code which can solve my query but you are able to attach and update the code?  OR  its not done till now and it will taken care in future by enhancement CCR 2167658 ?
    Regards
    Sonu
    I have some code that will alter the drop-down list as you type - that's what I'm struggling to upload at the moment. The enhancement will be more about showing the completion options directly in the type-in field (similar to that which happens for the ddHiCreateLibraryComboField/ddHiCreateCellComboField etc and for leCreateLayerField).
    So to clarify - the code I have works right now, but doesn't do everything the enhancement requests. It may be enough for your needs though.
  • Sonu Chopra
    Hello Andrew,
    Thanks for Clarification . But , if its alter the original drop down list (When user type-in) then there is an issue as when user select or type-in for the second time the drop down list will not be same as original list? OR you are altering the drop list locally and keep the same original drop down list as for next time then its really serving my purpose?
    Please share the code when its done :)
    Really thanks a-lot for the quick responses and help
    Regards
    Sonu
    So I'll post it as soon as I can!
  • Sonu Chopra
    Hello Andrew,
    Thanks for all the help.  I will wait for your update.
    Regards
    Sonu
    Hi Sonu,
    With help from my friend in IT, we managed to find a particular keyword in the code that it objects to - I rewrote the code to avoid that. Here's the updated code:
    let((cf)
        cf=hiCreateComboField(
            ?name 'cf
            ?items list("sonu" "andrew" "max" "anil")
            ?modifyCallback
                lambda((field form value flag)
                    let((len)
                        len=strlen(value)
                        form->cf->items=setof(item form->cf->allItems
                            strncmp(item value len)==0
                        t
        cf->allItems=cf->items
        hiCreateAppForm(
            ?name 'CCFform
            ?fields list(cf)
        hiDisplayForm(CCFform)
    Andrew Beckett over 6 years ago in reply to Andrew Beckett
    It didn't like substring in my original code, so I changed to use strncmp instead.
  • Sonu Chopra
    Hello Andrew,
    Thanks for the code. It really work fine for me. But There is one more point (Which may be quite complex to implement) that whenever I am typing something in drop down field its giving the filter list based on matching the case (its expected as you have used the strncmp) . Can we have the filter list result based on case insensitive search?
    For Example :- drop_down_list =("andrew" "sonu" "max" "anil").
    Currently as per your code if I am typing "A" its gives no result? Can We have some code which still gives the filter list as  "andrew" "anil" even if I type "A" in Drop Down Field?
    Thanks Again Andrew for all the help,
    Regards
    Sonu
    Hi Sonu,
    Use  strncmp(item lowerCase(value) len)==0 instead. This is assuming that allItems is entirely lower case. If not, you could put lowerCase(item) too...
