  3. How to Execute Unix Commands through CIW Window and Store...
  • Replies 21
  • Views 17140
How to Execute Unix Commands through CIW Window and Store the output in a variable on Unix/CIW Window (Rather than file)?
Sonu Chopra
Sonu Chopra over 6 years ago
Hello Support,
I have one query regrading the Execution of Unix Commands through CIW Window. Currently i am using system or sh/shell Command and i am storing the output in a file . Can there be a way that We Can Store the output in a variable itself (Accessible form Unix/CIW Window).
The Query is that i want to have the layer Map File Path and I want to store it to a variable (Don't want output  to redirect to file and i don't want to read the file to get the path in a variable if possible)
; Getting the LayerMapFile Path and Storing in a file
system("piGetInfo $DKITROOT lyrFilIn  >layermapfile.il")
Above Command is working Fine and layermapfile.il is containing the LayerMapFile Path
;Getting the LayerMapFile Path and Storing in a Variable
system("setenv layerMapFile `piGetInfo $DKITROOT lyrFilIn` ")
Above Command is throwing a error :- sh: setenv: command not found
Can you please provide some help on this?
Thanks in Advance,
Regards
Sonu
    Andrew Beckett over 6 years ago +1
    Hi Sonu, There are several things wrong here. First of all, "setenv" is a csh not sh command, and so it's not surprising that gives an error. Even if you'd used csh() instead of sh(), it wouldn't have…
  • mbracht
    mbracht over 6 years ago in reply to Sonu Chopra +1
    Hi Andrew, I think the idea is to repopulate the combo box each time you type something into the text field. So assume you start wit a list '("abc" "def" "auv") and then type 'a' into the text filed…
    Andrew Beckett over 6 years ago in reply to Sonu Chopra +1
    With my code there is no problem with deleting what you've typed in and then typing something else. It keeps the complete list of choices and updates starting from the complete set each time you type.…
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for the code. Yes its Working fine for me :).
    Regards
    Sonu
