  3. SKILL command to copy a library, including categories
  • Views 18705
Aldo2
Aldo2 over 6 years ago
I used ccpCopy command to copy a library using SKILL. Is it possible to copy categories as well?
Thank you
Best regards,
Aldo
    Hi Aldo,
    Yes, it seems to work. For example:
    miscCat=gdmCreateSpec("analogLib" "" "" "Misc.Cat" "CDBA")
    dl=gdmCreateSpec("RFworkshop" "" "" "" "CDBA")
    src=gdmCreateSpecList()
    dst=gdmCreateSpecList()
    gdmAddSpecToSpecList(miscCat src)
    gdmAddSpecToSpecList(dl dst)
    ccpCopy(src dst t)
    Note that it won't show up unless you either copy the top level category (e.g. analog.TopCat in the example above) - the updater will automatically rename that to RFworkshop.TopCat - or you recreate the top level category using the ddCat API.
  • Aldo2
    Aldo2 over 6 years ago in reply to Andrew Beckett
    Thank you Andrew.
    And for selecting them, I have to use a statement like:
    foreach(cellId ddGetObj(libNameNew)~>files...
    picking out *.Cat and *.TopCat files only, or there is an alternative way?
    Thank you
    BR,
    Aldo
    Andrew Beckett over 6 years ago in reply to Aldo2
    Hi Aldo,
    You could use the category APIs, so starting with ddCatGetLibCats(ddGetObj("analogLib")) to get the names of the library level categories, but then you'd have to find any sub-categories too. So pragmatically it might just be easier to pattern match for anything ending in .Cat or .TopCat (even though that feels wrong to me, it's probably simplest).
