  3. GUI basic function errors
  • Views 15449
uppalanchi
uppalanchi over 6 years ago
Hi all,
I am writing a skill code in order to load the bind keys of my choice using a popup. For that purpose i have written following code
but, i am facing errors while running in virtuoso 6-1-6-64b, & i am very new to skill coding
The errors are:
1.I am unable to close the pop up window( want to know the functionality of buttons like OK,cancel,apply & help)
2. the selected items are not storing in variable "i"
any suggestion or help regarding the issue is appreciated.
how can i get the more info for gui creation.
CODE:
my_frame_fld = hiCreateFrameField(
?name 'my_frame_fld
?labelText "selction_window"
?enabled t)
my_combo_fld = hiCreateComboField(
?name 'my_combo_fld
?prompt "tech_selcet"
?items '("gf28" "gpdk45" "tsmc130" )
?enabled t)
my_form = hiCreateAppForm(
?callback "callback_fun()"
?name ‘my_form
?formTitle "Bindkeys"
?buttonLayout '(OKCancelApply)
?fields list(
list(my_frame_fld (10:10) (450:100) 100)
list(my_combo_fld (30:40) (425:10) 100)
?initialSize t)
hiDisplayForm(my_form)
procedure(callback_fun()
i=my_form~>my_combo_fld~>value
if((i=="gf28")
then
load("home/Desktop/123/28nmbindkeys.il")
printf("done 28nmbindkeys file ")
if((i=="gpdk45")
then
load("home/Desktop/123/45nmbindkey.il")
printf("done 45nmbindkeys file ")
if((i=="tsmc130")
then
load("home/Desktop/123/130nmbindkey.il")
printf("done 130nmbindkeys file ")
    I reformatted the code slightly to make it easier to read.
    I moved the callback function definition to be before the hiDisplayForm - as that will block and so the callback wouldn't have been defined. With that, it all worked OK (I commented out the actual load lines as I didn't have the files available). I then made i a local variable as it's not a good idea for it to be global (that said, the code worked without that).
      let((i)
        if((i=="gf28") then
            ;load("home/Desktop/123/28nmbindkeys.il")
        if((i=="gpdk45") then
            ;load("home/Desktop/123/45nmbindkey.il")
        if((i=="tsmc130") then
            ;load("home/Desktop/123/130nmbindkey.il")
        ?name 'my_frame_fld
        ?enabled t
        ?name 'my_combo_fld
        ?enabled t
        ?name 'my_form
        ?fields list(
        ?initialSize t
    So this all works OK. Not sure what your problem is? If the form is not being removed, did you by any chance put this within a block of code where my_frame_fld is defined in a let() and so is local?
