  3. passing parameter values from csv file
  • Views 18768
anode
anode over 6 years ago
Can anyone one let me know/show how to pass values of  PCell parameters from a csv file.
Many Thanks
Hosein
    Andrew Beckett over 6 years ago in reply to anode +1
    Hosein, I can't really write your code for you, but here's a very rough piece of code to do what you want. This is not thoroughly checked, and maybe you need more controls over the placement (this just…
    Hi Hosein,
    What do you mean by "pass values of PCell parameters from a csv file"? What's in the CSV file? What are you expecting? PCell parameters are passed to the instance of a PCell, so it's unclear what you want here.
  • anode
    anode over 6 years ago in reply to Andrew Beckett
    Thanks I found a workaround using some scripting .
    But here is my question.
    I have a Pcell with parameter such as length , width, pitch etc ..
    I have Excel sheet with these parameters and their numerous values . I wanted to write a code into my Pcell that could read the data from Excel sheet and produce many variiation of the PCell depending on the parameter values . This way can automate the Pcell which is controlled by the Excell sheet as and when different values called from the Excel sheet when ever user wanted.
    I had used some skill function to read the data and print it but was unable to relate them to my Pcell parameters.
    Best Regards
    Hosein
    Hi Hosein,
    There's no standard (public) function for reading an Excel spreadsheet or a CSV (we do have some capability in PCell Designer to read Excel to do this kind of thing, but it's not a public SKILL capability). You could write your own function to read CSV (that's not hard) and then use the data  you read to loop over the rows and then place instances with each of the parameters.This is straightforward enough to do with basic SKILL knowledge.
  • anode
    Hi Andrew
    Thanks for your reply.
    Although I understand the general concept but perhaps you would elaborate with couple lines of syntax how to read the rows lines by line and pass it to PCell parameters .
    Regards
    Hosein
    Hosein,
    I can't really write your code for you, but here's a very rough piece of code to do what you want. This is not thoroughly checked, and maybe you need more controls over the placement (this just steps the x value each time). It also isn't a very general CSV reader. Hopefully it will give you some ideas though - I did test it with a gpdk045 nmos1v device:
    *                     CCFreadCSV(fileName)                     *
    *  Read a CSV file - returns a list of param names (the first  *
    *     row), and then a list of list of values (in order).      *
    *    Does not attempt to handle quoted strings - leave that    *
    *                as an exercise for the reader.                *
    procedure(CCFreadCSV(fileName)
        let((paramNames values inp line rows trailCR)
            ; pattern for trailing carriage return
            trailCR=pcreCompile("\n$")
            inp=infile(fileName)
            ; First read the parameter names, then the rows of values.
            ; Uses tconc to ensure lines read in order
            when(inp && gets(line inp)
                line=pcreReplace(trailCR line "" 1)
                paramNames=parseString(line ",")
                while(gets(line inp)
                    values=parseString(line ",")
                    rows=tconc(rows values)
            when(inp
                close(inp)
            list(paramNames car(rows))
    *          CCFplaceFromCSV(fileName libName cellName           *
    *             @key (viewName "layout") (step 2.0)              *
    *                 (cvId geGetEditCellView()))                  *
    *       Read parameter information from a file and place       *
    *              the instances, separated by step.               *
    procedure(CCFplaceFromCSV(fileName libName cellName
            @key (viewName "layout") (step 2.0) (cvId geGetEditCellView()))
        let((param paramList master (x 0.0))
            master=dbOpenCellViewByType(libName cellName viewName)
            destructuringBind((paramNames rows) CCFreadCSV(fileName)
                foreach(row rows
                    ; Convert the row into a list of lists suitable for
                    ; dbCreateParamList, converting the value to the right
                    ; type for the expected pCell parameter
                    paramList=foreach(mapcar (paramName value) paramNames row
                        param=dbFindProp(master~>parameters paramName)
                        case(param->valueType
                            ("float"
                                list(paramName "float" cdfParseFloatString(value))
                            ("boolean"
                                list(paramName "boolean" value=="t")
                            ("int"
                                list(paramName "int" atoi(value))
                            (t
                                list(paramName "string" value)
                    ; Then place and increment the current location
                    dbCreateParamInst(cvId master "" x:0 "R0" 1 paramList)
                    x=x+step
            t
    Here's the CSV file I used to test it:
    fw,l,fingers,connectSD,switchSD,tap,tapCntRows
    600n,90n,5,Source,t,Detached,2
    800n,45n,3,Drain,nil,Integrated,1
    900n,45n,7,Both,nil,Integrated,1
    Finally, the SKILL function I called to test it:
    CCFplaceFromCSV("place.csv" "gpdk045" "nmos1v")
