  3. Printing to csv file with nil data
  • Views 16593
TeeBro
TeeBro over 6 years ago
Hi All,
I'm reading some values from an extracted view and would like to print the values to a csv file.  I have created a table and would like to have a simple print statement to walk through the table printing the values.
The table looks like signal1 --> signal2 --> pass --> value.
The trouble is not all passes have a value.
For example the table might look like this:
signal1 --> signal2 --> pass1 --> 5
signal1 --> signal2 --> pass2 --> 6
signal1 --> signal3 --> pass3 --> 7
Notice there is no signal1 --> signal3 -->pass1 or signal1--> signal3 -->pass2
I want the output csv file to be the following:
signal1,signal2,pass1,5
signal1,signal2,pass2,6
signal1,signal3,,
signal1,signal3,,
signal1,signal3,pass3,7
Any ideas would be appreciated.
    If you have a value that you've retrieved from the table, and are about to print it with %s in a printf statement, isn't this just a matter of doing:
    unless(value value="")
    Or if it was an integer in the table, doing something like:
    if(value then
      sprintf(value "%d" value)
    else
      value=""
    Perhaps I'm missing something? If I am, it's probably because you didn't give any specifics about what's in the table or how it's structured, or how you're writing the CSV.
  • TeeBro
    TeeBro over 6 years ago in reply to Andrew Beckett
    Thanks Andrew!  I was making the task too complicated.  Sometimes you just need to put the code down for a while.8-)
    Andrew Beckett over 6 years ago in reply to TeeBro
    Don't worry! It happens to us all!
