  3. LE-109031 pop up while using leMoveCellViewOrigin
  • Views 15728
Chikoo
Chikoo over 6 years ago
I am using leMoveCellViewOrigin function for moving origin for set of 100+ cells.I am getting pop up LE-109031 asking "Would you like to rearrange objects taking snap boundary as origin ?" everytime.
If i click on "No" it will move the origin as expected.
Is there a way to disable this?
Thanks in advance
    Since you've opened case 46422131 I am not going to replicate the work of my colleague who is handling this. As far as I can tell, this will need an enhancement to suppress this popup when the procedural SKILL interface is used (I can't see an obvious way of preventing the popup, other than removing any snapBoundary objects first).
  • Chikoo
    Chikoo over 6 years ago in reply to Andrew Beckett
    Thanks for the response.I have not got any meaningful response for the ticket and hence had to post this as it is really gating my progress.
    Could you please help me identify what are snapBoundary objects and why are they created.
    It is a prexisting db and hence i do not have any history on why it is present.
    Thank you
    Andrew Beckett over 6 years ago in reply to Chikoo
    As I mentioned, it doesn't make sense to duplicate effort and have me work on this at the same time as my customer support colleague. So I would encourage you to work through your case to find a workaround (I've made some suggestions to the AE handling the case to avoid us duplicating effort).
  • Chikoo
    Thank you for helping speed up the procedure..I will await the response from the team working on it.
