  3. example code in pcDefinePPCell help doc does not work.
  • Views 15169
chaujohnthan
chaujohnthan over 6 years ago
it says rectWidth undefined function.
does not recognize the l_overrideCodeParams input?
    I used the code from the example (from the IC618 ISR9 documentation), and don't get any error with rectWidth being an undefined function. I don't know what the issue is that you're describing - perhaps you should paste the actual code you've used, as maybe you made an error during transcription?
    What are you actually trying to do with pcDefinePPCell (I don't think I've ever found a need for it myself)?
