  3. How to add a menu in both the CIW Window and all the layout...
  • Subscribers 152
  • Views 18687
How to add a menu in both the CIW Window and all the layout window (on opening) !!!
Sonu Chopra
Sonu Chopra over 6 years ago
Hello ,
I wanted to add a menu in both the CIW Window and all the layout window (on opening). I am able to add either in layout window or in CIW Window (not in both).
i am writing a dummy example to illustrate this
Skill code to illustrate addition of menu in Layout window :
procedure(AddMenu(args)
  let( (item1 item2)
    ;; create a couple of menu items
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "My First Item"
              ?callback "AmitFunctionOne()"
    item2 = hiCreateMenuItem( ?name 'item2 ?itemText "My Second Item"
              ?callback "AmitFunctionTwo()"
    ;; create a menu that includes the menu items and return a list of the
    ;; pulldown menus
    list(hiCreatePulldownMenu('AmitMenu "Amit Menu" list(item1 item2)))
  );let
); procedure
;; create a userMenuTrigger trigger that automatically adds the menu
deRegUserTriggers("maskLayout" nil 'AddMenu)
Skill code to add a menu to the CIW Window
procedure(AddMenu()
  let( (item1 item2)
    ;; pulldown menus
    CiwMenu = hiCreatePulldownMenu('AmitMenu "Amit Menu" list(item1 item2)))
    hiInsertBannerMenu( window(1) CiwMenu  3 )
  );let
); procedure
AddMenu()
Can you please guide me how i can add the menu to both CIW Window and Layout Window (on opening) ?
Regards
Sonu
  • henker
    henker over 6 years ago
    When you create the second menu using hiCreatePulldownMenu and the same symbol as menu handle, you are implicitely deleting the first. The menu handle is a unique global skill symbol (see documentation). This also means that you can get the menu from anywhere by accessing the symbol 'AmitMenu' in you case.
    So you either have to create the menus with a different menu handles on each creation (not really recommendend), or create the menu only once and insert this once created menu to where you want to have it.
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to henker
    Hello henker,
    I am not writing two separate procedures to insert in CIW and Layout Window. (That's why i am not having same symbols as you mentioned).  This was an dummy example to illustrate that I am able to generate menu separately for CIW or layout menu through a procedure. I don't know who I am able to do it with a single procedure and store it in my .cdsinit file.
    Regards
    Sonu
    Andrew Beckett over 6 years ago in reply to Sonu Chopra
    Here's how to do it. Share the code that creates the menu and only create it if it's not already bound:
    procedure(AmitCreateMenu()
      let( (item1 item2)
        ;; pulldown menus
    procedure(AmitAddMenu(args)
      unless(boundp('AmitMenu)
        AmitCreateMenu()
      list(AmitMenu)
    ); procedure
    procedure(AmitAddToCIW()
        AmitCreateMenu()
      hiInsertBannerMenu(hiGetCIWindow() AmitMenu  3 )
    deRegUserTriggers("maskLayout" nil 'AmitAddMenu)
    ; may need to initialise CIW menus before adding
    ciwMenuInit()
    AmitAddToCIW()
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Sorry for delay in reply.. thanks for your code and it works fine for him.
    Regards
    Sonu
