  3. Lint Manager Outputs
  • Subscribers 150
  • Views 16472
SrBraj
SrBraj over 6 years ago
Hello Cadence Community
I am checking my SKILL script with the Lint Manager which is giving me the following error/warning messages:
i. Error: " line 348 (createTbQrc) : runQrcCheck takes at most 6 non-keyed args : runQrcCheck(pdkLibName componentName aquaQrcCheckLibName outputDir recreateTB counter techLibName layerMapFileName lvsRuleFileName metOptFileName) "
The above line is an Error message by Lint manager, I am not sure that what is the meaning of non-keyed args.
ii. Warning Global: Unrecognized global variables
I am using a variable defined in the .cdsinit file in my script file. For the same variable, I am getting the above warning message. How can I resolve the above warning message?
iii. Error Global: Variables used as both global and local
I also have a GUI created using the SKILL code. A snippet of the code is mentioned below:
procedure( aquaQrcCheckForm()
aquaQrcForm = hiCreateAppForm(
?name 'aquaQrc
?formTitle "QRC Check"
?fields guifields
?initialSize width:(y+yStep)
?callback "aquaQrcCheck()"
hiDisplayForm(aquaQrcForm )
I am accessing the above UI fields from another SKILL procedure as aquaQrc ~> libName ~> value .
This error is regarding the use of aquaQrc variable from another SKILL procedure. What is the correct way to accessing the GUI fields value from another procedure?
  • SrBraj
    SrBraj over 6 years ago +1
    I am able to resolve the query # iii by adding the hiGetCurrentForm() as arguement in the callback procedure: procedure( aquaQrcCheckForm() .... .... .... aquaQrcForm = hiCreateAppForm( ?name…
    Andrew Beckett over 6 years ago in reply to SrBraj +1
    Expecting people to debug your lint messages without being able to see the code is a bit optimistic. You wouldn't ask a garage about a fault with a car merely by describing a scratch on the paintwork.…
  • SrBraj
    ?name 'aquaQrc
    ?fields guifields
    ?callback "aquaQrcCheck(hiGetCurrentForm())"
    Expecting people to debug your lint messages without being able to see the code is a bit optimistic. You wouldn't ask a garage about a fault with a car merely by describing a scratch on the paintwork. Some wild guesses:
    1. The function is defined as runQrcCheck(pdkLibName componentName aquaQrcCheckLibName outputDir recreateTB counter techLibName layerMapFileName lvsRuleFileName metOptFileName) - but you're calling it with runQrcCheck(?pdkLibName ...) - i.e. passing keyword arguments.
    2. Generally global variables should be given  prefix and then you tell Lint what that prefix is - then they can be classed as "OK" and recognised so it doesn't flag them as accidental keywords.
    3. The likely scenario here is that you've used the global variable name in a let or a function argument
    I suggest you post your code if you want more help.
  • SrBraj
    SrBraj over 6 years ago in reply to Andrew Beckett
    Hi Andrew
    Thanks for your quick reply. The problem is solved now and I am getting the 99/100 IQ score for my code.
    Well, there is nothing wrong with going to the garage and enquire about the fault in a car by describing a scratch if it has an expert like you. :)
    The main issue was that the back-up file of the same code was also loaded in the IDE, and because of that, I was unable to resolve it.
    Thanks once again!!
    Saurabh Raj
