  3. Get epoch time value in SKILL
  • Views 18297
Quesar
Quesar over 6 years ago
As the subject says, I would like to get the epoch time value in SKILL. I know it can be done through ipcBeginProcess and ipcReadProcess, but that seems a little heavy for such a simple task.
The function "getCurrentTime" only seems to return a nice string, but again, I don't want to go through the trouble of converting that to its epoch value. The function itself doesn't have any option to provide that either.
Is there any simple, direct way to obtain this, or must I resort to one of the above methods?
Thanks.
    Andrew Beckett over 6 years ago +1
    I assume you really don't mean the epoch time value - since that's 1st January 1970 00:00:00 UTC. You can (almost) get this using timeToString(1) - for some reason it doesn't work with 0 as the argument…
    I assume you really don't mean the epoch time value - since that's 1st January 1970 00:00:00 UTC. You can (almost) get this using timeToString(1) - for some reason it doesn't work with 0 as the argument, so you get 1 second after the epoch (in the time zone you're in).
    Anyway, I'm guessing you really want the time in seconds  since  the epoch? If so, there are several relevant functions here:
    Function Description
    stringToTime(dateStr) Converts a date string (like the output from getCurrentTime()) into the number of seconds since the Epoch (i.e. UNIX time)
    timeToString(timeInt) Opposite of stringToTime - converts a time since epoch value into a formatted string
    timeToTm(timeInt) Produces a structure with breakdown of year, month, date, hour, minutes, seconds - easy to decompose
    tmToTime(tm) Opposite of timeToTm - takes tm structure and converts back into a UNIX time since epoch
    getCurrentTime() Returns a formatted string with the current time
    compareTime(timeStr1 timeStr2) Compares two formatted date/time strings and returns the difference in seconds
    For more details use cdsFinder and then press the "more info" button to find the full documentation for each function.
    So no need to use IPC to do this (provided that my assumptions about what you mean by epoch are correct).
  • Quesar
    Quesar over 6 years ago in reply to Andrew Beckett
    Thanks Andrew! Yes, you're right, what I really meant was "time since the epoch in seconds". I found what I wanted with (stringToTime (getCurrentTime)) as you helpfully pointed out above.
    Thanks again!
