  3. Correct syntax for input stimulus with bus notation
  • Views 15978
ThomasThoe
ThomasThoe over 6 years ago
I am having some troubles creating an input stimulus file for my simulations when there are bus signals involved.
I am including a .scs file in a maestro view with the stimulus field. So for example (hopefully no c&p errors):
stim.scs
simulator lang=spectre
_vlayer_0 ([#layer_0<0>] 0) vsource type=dc dc=0
When running the netlister, my input.scs then includes a .scs file that resides in the /stimulus/ subdirectory and was seemingly created by the netlister. So the netlisting itself seems to complete.
The created stimulus netlist now has:
_vlayer_0 (layer_0<0> 0) vsource type=dc dc=0
Which when simulating causes:
Cannot run the simulation because the syntax error `Unexpected operator "<". Expected block statement,...
Is this a bug with the name mapping feature ? I would expect the generated netlist to have a backslash character before the <, but I might be wrong here. If I add extra backslashes, like [#bus\<0\>], then these get deleted as well by the mapping feature.
Any pointers on how to do this correctly ? The documentation unfortunately only links to an example that doesn't use bus notation.
Thanks a lot,
Thomas
