  3. Problem creating a custom via in layout
  • Views 14695
psill000
psill000 over 6 years ago
I am try to create a via in layout, but I am get a warning and the via is not created
The Warning
*WARNING* (DB-220810): dbCreateCustomVia: The creation of customVia with a cdsGenViaDef is not supported
The code I use that gets the warning ( same code with "M1V1M2" works )
techId = techGetTechFile(cvPwr)
viaDef0 = techFindViaDefByName(techId "CAVAM1")
dbCreateVia(cvPwr viaDef0 centerBox(lAnd~>bBox) "R0")
Current work around I can create a stdVia then replace with the custom via
leReplace(cvPwr viaList list(list("via definition" "==" "CAVAM1")))
Is there a better way to create the customVia
Paul
