  3. Calculate cutRows and cutColums for dbCreateVia from a given...
  • Views 15386
Calculate cutRows and cutColums for dbCreateVia from a given bounding box
nbuwen
nbuwen over 6 years ago
I have a short M1 path and a longer M2 path ontop of the M1 path in the Virtuoso layout view.
| - - - - | - - M1- - | - - - - |
Now, i want to connect these paths with a via with multiple rows and columns.
This is what i tried:
params = lxComputeViaParams(myViaDef cellView nil nil intersectionHeight "horizontal" intersectionWidth "vertical" nil)
dbCreateVia(cellView myViaDef intersectionCenter "R0" params)
Unfortunately this doesn't fill all the intersection space: especially cutColumns is too low. Setting intersectionWidth to a very high value doesn't increase the cutColumns any more.
I also tried to manually calculate the cutRows and cutColumns but then the Via shape didn't exactly fill the intersection space (this is my best option so far).
Interestingly the Via Property Editor (opened after selecting the via shape and pressing Q) allows me to calculate the cutRows and cutColumns from the dimensions of the intersection space. Also the via shape then perfectly fills the intersection space.
(I manually calculated 25 as the maximum number of cutColums and it auto filled 4.46 as the width. The correct width is 4.5 in this case. If i enter the correct width everything is perfect, but i can't do that in SKILL)
So my question is: How can i calculate the dimensions for the via shape and the maximum number of cutRows and cutColumns given the width and height of the intersection space in SKILL just as the GUI does it.
Greetings,
Niels
Edit:
I also looked at the via* functions like viaGenerateViasInArea but they seem to require a higher license.
Virtuoso version as per getVersion() is ICADVM18.1-64b 03/10/220
