  3. How to set ADE-XL/Maestro to a given position and size
  • Replies 14
  • Views 11375
netbug
netbug over 6 years ago
Hi all,
I would like, whenever I open an ade-xl/maestro session, to center the window and resize it to a given width x height.
This is because I am using two displays as one and don't want every time I maximize the window, for it to span across both screens. So it would be handy to customize size and position.
Thanks in advance.
Best regards,
Pedro
    Andrew Beckett over 6 years ago in reply to netbug +1
    Hi Pedro, I've considered it - the main challenge would be finding the time. Writing a book takes quite a bit of time and juggling that with all the other things I do would be a challenge. Many years…
  • skillUser
    skillUser over 6 years ago
    Hi Pedro,
    I see the following .cdsenv variables for the size of the window, but not the bbox or size + location :
        maestro.window width int 1200
        maestro.window height int 0
    Hopefully this helps?  The comment is that if the value is zero it uses the session window width/height, so perhaps set the above to 0 and use the schematic window bbox to determine the size & location?
    Best regards,
    Lawrence.
  • netbug
    netbug over 6 years ago in reply to skillUser
    Hi Laurence,
    Thanks for your reply. Where can I find a list of all "properties" of a tool. I know properties is the wrong word but I don't know it's name.
    I am referring to things like:
    maestro.window
    viva.graphLabel
    Viva.graphFrame
    etc etc
    Best regards,
    Pedro
    In IC6.1.8 and ICADVM18.1 there's Options->Cdsenv Editor where you can search for such settings.
    Not sure that's what you want, but it may help.
  • netbug
    netbug over 6 years ago in reply to Andrew Beckett
    Thanks Andrew.
    Best regards,
    Pedro
  • skillUser
    skillUser over 6 years ago in reply to netbug
    Hi Pedro,
    To find the above information I looked in the installation file: `cds_root virtuoso`/tools/dfII/etc/tools/maestro/.cdsenv - this is the file that Virtuoso read (each tool has its own for default settings, e.g. layout, schematic and so on).
    Best regards,
    Lawrence.
  • netbug
    Great !
    Thanks both.
    Best regards,
    Pedro
  • netbug
    Andrew Beckett
    Good morning,
    I have discovered a linux command (maybe you know it) that gives both the coordinates and dimensions of a given window.
    So, you can do the following:
    1. position and stretch any window the way you want
    2. enter, on a linux terminal, the command "xwininfo"
    3. click the window you would like to get the information from
    You should end up with a result like the one below.
    xwininfo: Please select the window about which you
    would like information by clicking the
    mouse in that window.
    xwininfo: Window id: 0x2400003 "Terminal"
    Absolute upper-left X: 2
    Absolute upper-left Y: 57
    Relative upper-left X: 2
    Relative upper-left Y: 26
    Width: 1917
    Height: 1067
    Depth: 24
    Visual: 0x23
    Visual Class: TrueColor
    Border width: 0
    Class: InputOutput
    Colormap: 0x20 (installed)
    Bit Gravity State: NorthWestGravity
    Window Gravity State: NorthWestGravity
    Backing Store State: NotUseful
    Save Under State: no
    Map State: IsViewable
    Override Redirect State: no
    Corners: +2+57 -1921+57 -1921-54 +2-54
    -geometry 190x52+0+31
    Best regards,
    Pedro
    PS: I am sorry if you already knew this.
    Or rather more simply, in Virtuoso you can find this out using:
    hiGetAbsWindowScreenBBox(hiGetCurrentWindow())
    (the numbers are slightly different because it doesn't include all the window manager decorations, I believe). You can move the window using hiResizeWindow(...)
  • netbug
    Thanks Andrew.
    Is it possible to associate those instructions to an event triggered when the maximize button is pressed?
    The goal of all of this is to resize the window for a given size, without maximizing it.
    The reason behind this, is that I am using  VNC Viewer to control multiple monitors, buy they are seen as one monitor. Anytime I pressed the maximize button will span the windows across all monitors.
    So I would like to redefine what the maximize button does to fit one screen only.
    Thanks.
    No, sorry. There's no trigger mechanism for this. The maximise button is part of the window manager, and not directly accessible by Virtuoso. I did wonder whether hiRegZoomPanProc would help, but maximise doesn't necessarily trigger a redraw, so it doesn't get called.
