  3. Top metal information to get the entire library cell vi...
  • Views 17151
Top metal information to get the entire library cell views
Purge2343
Purge2343 over 6 years ago
procedure(abGetHighestLayer(@key (cv dbOpenCellViewByType(library_name cell_name "layout" "maskLayout" "r")) (function "metal")
acrossHierarchy)
let((tf topToBottom usedLayers)
; Figure out the order of the layers matching the given function
; and put it in reverse order
tf=techGetTechFile(cv)
topToBottom=reverse(
mapcar('car
setof(layerFunc techGetLayerFunctions(tf) cadr(layerFunc)==function)
; Now collect all the layers used in the design. If ?acrossHierarchy t
; was provided, then include those in lower level cellViews (if opened)
usedLayers=makeTable('usedLayers nil)
foreach(lpp cv~>lpps
when(acrossHierarchy || !zerop(lpp~>nShapes)
usedLayers[lpp~>layerName]=t
; Find the first top to bottom layer that's in the design
car(exists(layer topToBottom usedLayers[layer]))
printf("cell Name %s\n",cell_name)
printf("Metal value %s\n",abGetHighestLayer())
filePtr = outfile("metal.txt" "a")
ocnPrint( ?output filePtr cell_name)
ocnPrint( ?output filePtr abGetHighestLayer())
hiRegTimer("exit()" 40)
I got this code from online.
I wanted to know if I want send just the library name and get entire library cell views metal information.
Kindly let me know where I can add foreach loop to get the information i needed.
    This is very odd. You've taken the code in this post and changed the default value of cv in a way that doesn't make a great deal of sense.
    You've then got a strange mix of print statements and OCEAN print statements to produce a report. I also have no idea why you're using hiRegTimer to exit the script.
    If you are trying to find the the highest metal layer in all layout views in a library, then something like this would work:
    /* abHighestLayerInAllCells.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 06, 2020
    Modified
    By
    Produce a report of the highest metal layer for each
    cell in a library.
    Uses abGetHighestLayer
    SCCS Info: @(#) abHighestLayerInAllCells.il 04/06/20.18:23:51 1.1
    *               abHighestLayerInAllCells(libName reportFile)               *
    * Produce a report listing the highest metal layer in each layout cellView *
    *                               in a library                               *
    procedure(abHighestLayerInAllCells(libName reportFile)
        let((lib fout masterFile cv highest)
            fout=outfile(reportFile)
            unless(fout
                error("Cannot write to file %L\n" reportFile)
            lib=ddGetObj(libName)
            foreach(cell lib~>cells
                foreach(view cell~>views
                    masterFile=ddGetObj(libName cell~>name view~>name "*")
                    when(masterFile && ddMapGetFileViewType(masterFile)=="maskLayout"
                        cv=dbOpenCellViewByType(libName cell~>name view~>name)
                        when(cv
                            highest=abGetHighestLayer(?cv cv)
                            when(highest
                                fprintf(fout "%s %s %s\n" cell~>name view~>name
                                    highest
                            dbClose(cv)
            close(fout)
  • Purge2343
    Purge2343 over 6 years ago in reply to Andrew Beckett
    Thank you
    Is there any change I can make on this code to get via information as well?
    Andrew Beckett over 6 years ago in reply to Purge2343
    Yes. If you know what you mean by "via information", then I'm sure you can make changes to the code to add that. Unfortunately I don't know what you mean by "via information", so I can't help with the specifics.
  • Purge2343
    Thank you for your response.
    I mean to get the  information of the top or the highest via layer used in the layout.
    In the innermost loop (next to where it assigns the highest variable), you could use something like:
    highestCut=abGetHighestLayer(?cv cv ?function "cut") || ""
    (add highestCut into the local variables in the let) and then update the fprintf statement to print out the value of highestCut too. I added the || "" so that it returned a blank string if there's no cut layers in the cellView.
