  3. where and how to get stored skill files in cadence
  • Views 20104
raegaan
raegaan over 6 years ago
Hello
Can someone help me on how/where can I find the stored skill codes in cadence virtuoso??
Thanks and regards
Raegaan
    Hi Raegaan,
    I don’t understand your question. What do you mean by “the stored skill codes”?
  • skillUser
    skillUser over 6 years ago
    Hi Reagan,
    Your question was non-specific.  Here are some directories in your Virtuoso installation that contain SKILL code examples (in subdirectories):
    <virtuoso_install_dir>/share/cdssetup/dfII/
    <virtuoso_install_dir>/tools/dfII/etc
    <virtuoso_install_dir>/tools/dfII/samples
    and so on - these locations and the files can be found using 'find', e.g. find <virtuoso_install_dir> -type f -name '*.il'
    I suspect this is not what you are looking for, but then I have answered the question that was posed.
    Best regards,
    Lawrence.
  • raegaan
    raegaan over 6 years ago in reply to Andrew Beckett
    By stored skill codes I mean , the codes for each form or pcell that is ready to use.
    regards
    Raegaan
  • raegaan
    raegaan over 6 years ago in reply to skillUser
    I am looking for this only but can you elaborate on this. with <virtuoso_install_dir> you mean my workspace??
    Regards
    Raegaan
    Andrew Beckett over 6 years ago in reply to raegaan
    Your question still doesn't make any sense. I don't know what "each for or pcell that is ready to use" means.
    If you're asking where the source code for Cadence tools is, then we don't provide that. We provide all the code needed to generate the forms that are part of the tools in a binary form so you can't see the source. If you're asking where the source code for parameterised cells as part of a process design kit is, then usually that's not provided by the foundry either - they either encrypt any code or have it shipped in a context file (which is a binary representation).
    If you're asking about code you've written (which I doubt, because of your question), then you'd know where it is. If you're asking about code written for local utilities at your site, you'd need to speak to whomever is responsible for that.
    To answer the question about the <virtuoso_install_dir> in your response to Lawrence's attempt to answer your very vague question, you can find that by typing cdsGetInstPath() in the CIW. It's the directory containing the software installation for Virtuoso.
  • raegaan
    hi
    Thanks got what I wanted
    raegaan
