  3. change lib name and cell name
  • Subscribers 150
  • Views 17681
Nhumai
Nhumai over 6 years ago
Hi ,
my design contain standard cells from lib sc12sk_7m_v1 now I need to switch it to use standard cell from lib sc12tps_lvt_v1 . The cells name in sc12tps_lvt_v1 have "_l" at the end compare to cells name in sc12sk_7m_v1. I came up with a script below but it doesn't work and didn't give me any errors. Please let me know what is wrong
thanks
Nhumai
procedure( NlsbfLibReplace(libraryName)
lib1 = ddGetObj(libraryName)
foreach( cell lib1->cells
   viewmatch = nil
   foreach( view (cell->views)
      if( (view->name == "schematic")  then  viewmatch = t )
   if( (viewmatch == t) then
      win = geOpen(?window hiCreateWindow('default "graphics" "test1") ?lib libraryName ?cell cell->name ?view "schematic" ?viewType "schematic" ?mode "a")
      rep1 = getWindowRep(win)
      insts = rep1->instances
      foreach(instHeader cv~>instHeaders
             when(instHeader~>libName=="sc12sk_7m_v1" && rexExecute(instHeader~>cellName)
                  newCellName=strncat(instHeader~>cellName "_l" 1)
                  printf("The left coord is %L\n" newCellName)
                  dbSetInstHeaderMasterName(instHeader "sc12tps_lvt_v1" newCellName instHeader~>viewName)
      schHiCheckAndSave()
      hiCloseWindow(win)
  • skillUser
    skillUser over 6 years ago
    Try some of the pre-written SKILL examples perhaps (e.g. from the Custom IC Design SKILL Code Library [Custom IC Design SKILL Code Library]) ?
    Here's a link to one for changing cell references: 11330942
    Here's another for changing specific cells in a cellview: 11330954
    Hopefully this helps you.
    Best regards,
    Lawrence.
