  3. Diva DRC error markers not found by dbMarkerQuery
  • Views 15953
Quesar
Quesar over 6 years ago
Hi to anyone reading this,
I wrote a simple Diva DRC rule deck and executed it with ivDRC, and there are marker layer polygons representing the errors. I can find the marker layers using the GUI.
However, I would like to use SKILL to locate them for further processing. It seems there is a function just for that purpose, dbMarkerQuery. But when I used it as below:
mycv = dbOpenCellViewByType(...)
dbMarkerQuery(mycv mycv->bBox)
The return value is always nil. The cellview mycv already contains the error marker shapes. I have also ensured that all the required cellviews are already loaded with dbOpenHier as mentioned in the manual, and I can also see that they are opened when I open the "Close Data" form through the CIW File menu. So there is no question that the subcells are not opened.
I've tried to find other functions to search for markers, but it seems this is the only function available. I think another thing I can do is process all the shapes in the cellview to find the marker shapes, but I really don't want to do that unless I have no choice, as it is inefficient as one might expect.
So, what options do I have here, and why does dbMarkerQuery not work as I expect it to?
My Virtuoso version is IC617ISR23 if that helps.
Any help would be appreciated. Thank you.
    Andrew Beckett over 6 years ago +1
    Diva still creates old style markers (the way they were created before OpenAccess) where they were represented as shapes on the marker/error or marker/warning layer-purposes. So you can find them using…
    So you can find them using:
    markers=car(exists(LP cv~>lpps LP~>layerName=="marker" && LP~>purpose=="error"))~>shapes
    You can change the purpose check to "warnng" if it's warning markers you're after. This is fairly efficient because it only has to search through the number of layer-purposes that exist in the design hierarchy, which should be a relatively small number, and is much faster than searching through millions of shapes in a big  layout.
  • Quesar
    Quesar over 6 years ago in reply to Andrew Beckett
    Thank you very much Andrew for the detailed explanation and solution as always!
