  3. How to update a dialog Form dynamiclly
  • Views 15055
YangKe
YangKe over 6 years ago
    In my code I try to update a String field dynamiclly and it does not work, in the string filed is only displayed at the end Step 30, the dialog is blocked during the call back function, what can I do here?
procedure(myCreateForm()
let((str button)
str = hiCreateStringField(
?name 'testStr
?prompt "Test String :"
?editable nil
button = hiCreateButton(
?name 'testButton
?callback "myCallBack(hiGetCurrentForm())"
?buttonText "Start"
?invisible nil
?enabled t)
hiCreateAppForm(
?name 'myFrame
?formTitle "Test"
?fields
list(str button)
?buttonLayout 'Close
?dontBlock t
procedure(myCallBack(theForm)
let((num)
num = 0
while( num < 30
num = num+1
theForm->testStr->value = sprintf(a "Step %d" num)
printf("Step %d\n" num)
;do something here
ipcSleep(1)
dialog = myCreateForm()
hiDisplayForm(dialog)
    Andrew Beckett over 6 years ago +1
    Call hiFlush() at the point where you have your "do something here" comment. Note there is a specific UI for doing this kind of progress indicator - hiDisplayProgressBox - there's also hiShowProgressBar…
    Call hiFlush() at the point where you have your "do something here" comment. Note there is a specific UI for doing this kind of progress indicator - hiDisplayProgressBox - there's also hiShowProgressBar for having a progress bar in a window.
  • YangKe
    YangKe over 6 years ago in reply to Andrew Beckett
    Thanks Andrew!
    It works.
