  3. To Replace part of Label Name (Not the Complete Label) in...
  • Views 15370
To Replace part of Label Name (Not the Complete Label) in Design !!!
Sonu Chopra
Sonu Chopra over 6 years ago
Hello ,
I Want to Replace Part of Label Name (not the complete label)  in a Design (Containing lots of Labels) . I have the Tried the rex , pcre functions but not able to solve this issue.
I am explaining the issue with an example :
label_Shapes_Id = setof(i cv~>shapes i~>layerName == "text" && i~>purpose == "drawing")~>theLabel   --> List of Labels in Design
Output :-
("Seperated" "Point Touch" "VTL_P;drawing_Corner to_VTL25_P;drawing_Edge" "VTL25_P;drawing_Corner to_VTL_P;drawing_Edge" "Overlap"
"Abutment" "Donut_VTL25_P;drawing_Abut_to_VTL_P;drawing" "Donut_VTL_P;drawing_Abut_to_VTL25_P;drawing" "VTL_P;drawing_Inside_VTL25_P;drawing" "VTL25_P;drawing_Inside_VTL_P;drawing"
"Line on Line" "VTL25_P;drawing_at_ortho_overlap_VTL_P;drawing_at_45_Degree" "VTL_P;drawing_at_ortho_overlap_VTL25_P;drawing_at_45_Degree" "VTL25_P;drawing_overlap_VTL_P;drawing_at_45_Degree" "VTL25_P;drawing_Abut_VTL_P;drawing_at_45_Degree"
"VTL_P;drawing_at_45_Inside_VTL25_P;drawing_at_orthogonal" "VTL25_P;drawing_at_45_Inside_VTL_P;drawing_at_orthogonal" "VTL_P;drawing_at_Orthogonal_Inside_VTL25_P;drawing_at_45" "VTL25_P;drawing_at_Orthogonal_Inside_VTL_P;drawing_at_45" "VTL_P;drawing_Inside_VTL25_P;drawing_at_45"
"VTL25_P;drawing_Inside_VTL_P;drawing_at_45" "Seperated" "Point Touch" "VTH_P;drawing_Corner to_VTL25_P;drawing_Edge" "VTL25_P;drawing_Corner to_VTH_P;drawing_Edge"
"Overlap" "Abutment" "Donut_VTL25_P;drawing_Abut_to_VTH_P;drawing" "Donut_VTH_P;drawing_Abut_to_VTL25_P;drawing" "VTH_P;drawing_Inside_VTL25_P;drawing"
"VTL25_P;drawing_Inside_VTH_P;drawing" "Line on Line" "VTL25_P;drawing_at_ortho_overlap_VTH_P;drawing_at_45_Degree" "VTH_P;drawing_at_ortho_overlap_VTL25_P;drawing_at_45_Degree" "VTL25_P;drawing_overlap_VTH_P;drawing_at_45_Degree"
"VTL25_P;drawing_Abut_VTH_P;drawing_at_45_Degree" "VTH_P;drawing_at_45_Inside_VTL25_P;drawing_at_orthogonal" "VTL25_P;drawing_at_45_Inside_VTH_P;drawing_at_orthogonal" "VTH_P;drawing_at_Orthogonal_Inside_VTL25_P;drawing_at_45" "VTL25_P;drawing_at_Orthogonal_Inside_VTH_P;drawing_at_45"
"VTH_P;drawing_Inside_VTL25_P;drawing_at_45" "VTL25_P;drawing_Inside_VTH_P;drawing_at_45" "GOOD CASES" "BAD CASES" "VTL25_P.R.6"
In the Above Output , I want to Replace VTL_25;drawing and VTH_P;drawing in the label name with NW;drawing and OD;drawing (with another layers).
Could You please help me on this point ?
Regards
Sonu
  • mbracht
    mbracht over 6 years ago +1
    Hi Sonu, I take it that you want to replace just the labels' text not the layers and purposes they are on - correct? (foreach label label_Shapes_Id label->theLabel=(pcreReplace (pcreCompile "VTL_25;drawing…
  • mbracht
    Hi Sonu,
    label->theLabel=(pcreReplace (pcreCompile "VTL_25;drawing") label->theLabel "NW;drawing" 0)
    label->theLabel=(pcreReplace (pcreCompile "VTH_P;drawing") label->theLabel "OD;drawing" 0)
    Max
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to mbracht
    Hello Max,
    Yes you are Correct (I only want to change label name) and I have tried your solution , Its work Perfectly fine at my end.
    Thanks for all the help and quick Response.
    Regards
    Sonu
