  3. hiGetAbsWindowScreenBBox() and view()
  • Views 15472
Aldo2
Aldo2 over 6 years ago
I would like to open a file, through view(), always in the same position.
I am using hiGetAbsWindowScreenBBox() to get the boxSpec value for view(), but I have a 30pt-shift in y direction (correction is in red.)
if(boundp('viewFile) && windowp(viewFile) then
    boxSpec=hiGetAbsWindowScreenBBox(viewFile)
    boxSpec=list(list(caar(boxSpec) cadar(boxSpec)-30) list(caadr(boxSpec) cadadr(boxSpec)-30))
    hiCloseWindow(viewFile)
    viewFile=view(hiGetCurrentForm()~>strFile~>value boxSpec)
else
    viewFile=view(hiGetCurrentForm()~>strFile~>value nil    )
Thank you,
Aldo
  • skillUser
    skillUser over 6 years ago
    Hi Aldo,
    Have you tried including a non-nil value to the optional argument to the hiGetAbsWindowScreenBBox function:
    hiGetAbsWindowScreenBBox(w_windowId [g_includeWMOffsets] )
    This doesn't fully eliminate the need for correction, but should reduce it greatly.
    Best regards,
    Lawrence.
  • Aldo2
    Aldo2 over 6 years ago in reply to skillUser
    Hi Lawrence,
    I have tried now, but, as you says, there is an offset also in this case.
    I could get the real y-offset value (30 in my case) as cadddr(hiGetWMOffsets()), but I do not know if this is a general solution for any windows manager.
    What do you think?
    Thank you very much
    Best regards,
    Aldo
    Andrew Beckett over 6 years ago in reply to Aldo2
    Hi Aldo,
    It's been a while since I looked into the precise nature of window manager offsets across different window managers, but I do know in the past some window managers were less well behaved about honouring precise coordinates. Without experimenting with a lot of window managers, I'm not sure I could confidently say this will work OK.
    However, I would ask why you need to close and recreate the window each time. Why not use hiSetViewfile(viewWindow newFile) to update the existing window to the new file contents? Then it will stay exactly where it was before...
  • Aldo2
    Aldo2 over 6 years ago in reply to Andrew Beckett
    hiSetViewfile() works fine. It is the best solution for me.
    Thank you very much
    Best regards,
    Aldo
