  3. hiCreateAppForm() callback to print field value
  • Views 17982
ajayghoshmv
ajayghoshmv over 6 years ago
Hi
I created a Form with stringFileds and corresponding ButtonFields.
I need The stringField value to be printed to a file when corresponding ButtonField is clicked.
stringF1   ButtonF1
stringF2   ButtonF2
stringF3   ButtonF3
stringFN   ButtonFN
I get below error. Could you please  help with solution or suggest alternate method ?
*Error* funcall: argument #1 should be a function object or name (type template = "ug") - nil
If my understanding is correct, the error is because I am trying to assign filed handle to a variable [ d1 here in my code].
excerpt from my code;
hiCreateButton(
?name 'ButtonFN
?buttonText "Submit"
?callback 'Sclose
procedure(Sclose(field form "og")
n2=atoi(car(parseString(artMakeString(field) "ButtonF")))
d1=concat("stringF" artMakeString(n2))
toFile=outfile("report.txt")
fprintf(toFile "%s\n" form->d1->value)
close(toFile)
);procedure
Ajay
    Hi Ajay,
    Which IC subversion are you using? (i.e. what does getVersion(t) return)? For me this worked, although the Sclose function didn't fully work mainly because form->d1->value won't work as d1 needs to be evaluated, but I changed it as follows:
    hiCreateAppForm(
      ?name 'forumForm
      ?fields list(
        hiCreateStringField(
          ?name 'stringF1
          ?value "testing"
        hiCreateButton(
          ?name 'ButtonF1
          ?callback 'Sclose
      let((n2 d1 toFile)
        ; use symbolToString rather than an ADE-specific function
        n2=atoi(car(parseString(symbolToString(field->hiFieldSym) "ButtonF")))
        d1=concat("stringF" n2)
        ; can't use form->d1->value because you need d1 to be evaluated
        fprintf(toFile "%s\n" get(form d1)->value)
        close(toFile)
    );procedure
    hiDisplayForm(forumForm)
  • ajayghoshmv
    ajayghoshmv over 6 years ago in reply to Andrew Beckett
    Thank you for the quick reply.
    I am using  "sub-version  ICADV12.3-64b.500.22 ".
    As suggested replaced "form->d1->value " with get(form d1)->value. This worked perfectly fine for me. Thanks again.
    Ajay
    Andrew Beckett over 6 years ago in reply to ajayghoshmv
    Hi Ajay,
    Not sure why it would have been failing with the funcall error earlier because using form->d1->value wouldn't have caused that (it gave a different error), but glad it's resolved now!
