  3. Split a large database into smaller "databases"
  • Views 1105
netbug
netbug over 6 years ago
I often run simulations under ADE-XL/Assembler which are quite large and, thus, take a long while to process.
Some questions:
1 - After identifying the corners of interest, is it possible to create a new database with that data only?
2 - Imagine that you run a simulation with several tests, which the user (me, in this case) hasn't assessed correctly the amount of data that would be saved and that it would take forever to process. If this is a long simulation, it would be super useful to be able to break the database in small chunks. for, example, per test.
 Thanks in advance.
Best regards,
Pedro
