  3. Multiple commands using ipcBeginProcess
  • Views 15723
ajayghoshmv
ajayghoshmv over 6 years ago
I am trying to use "sed -e 's " from SKILL code to edit unix file "FileA", to replace 3 words in the 2nd line.
How to run below multiple commands using  ipcBeginProcess, Should I use ipcWait or ipcCloseProcess ?
Using && to combine , will that work as I have to work serially on each command. ?
With below code only the first command gets executed. Please advise.
FileA="/user/tmp/text1.txt"
sprintf(Command1 "sed -e '2s/%s/%s/g' %s > %s" comment1 get(form concat("dComment" RDWn))->value FileA FileA)
cid = ipcBeginProcess(Command1)
sprintf(Command2 "sed -e '2s/%s/%s/g' %s > %s"  Time getCurrentTime() FileA FileA)
cid1 = ipcBeginProcess(Command2)
sprintf(Command3 "sed -e '2s/%s/%s/g' %s > %s"  comment2 get(form concat("Duser" RDWn))->value FileA FileA)
cid2 = ipcBeginProcess(Command3)
Ajay
  • mbracht
    mbracht over 6 years ago
    Hi Ajay,
    One way to make your life easier would be to use perl's "edit in place" feature,- assume you want to replace 'red' against 'green' in FileA you might go like this:
    ipc = (ipcBeginProcess (strcat "perl -i -p -e 's/red/green/g' /" FileA))
    (ipcWait ipc)
    The (ipcWait) waits for the perl child process to return - so when it comes back you can be sure the file is modified.
    Max
  • ajayghoshmv
    ajayghoshmv over 6 years ago in reply to mbracht
    Hi Max,
    Thank you for the input. Perl helped in my code.
    Regards
    Ajay
