  3. Not able to close a form
  • Views 16311
vishwas H A
vishwas H A over 6 years ago
I am trying to write a skill code where it takes form inputs by default and just displays tree directly.
i have written below code,
procedure( create_tree()
let(()
leHiTree()
leTreeForm->treeOption->value="Current to user level"
leTreeForm->userLevel->value= 31
ipcSleep(1)
hiFormDone(leTreeForm)
the form takes in values but it is not closing.
tried with regtimer in place of ipc sleep, didn't work.
how to close form(should be same as pressing OK)?
Thanks in advance,
vishwas
    Andrew Beckett over 6 years ago +1
    Hi Vishwas, The issue is that the leHiTree() function is blocking, and so you have to enqueue (or use hiRegTimer with 0) the commands to manipulate the form before the command is launched: procedure…
    Hi Vishwas,
    procedure(CCFcompleteTreeForm()
        leTreeForm->userLevel->value=31
    procedure(CCFcreateTree()
        hiEnqueueCmd("CCFcompleteTreeForm()")
        ;hiRegTimer("CCFcompleteTreeForm()" 0)
        leHiTree()
    Alternatively, you could use the code in this article instead: How to print a hierarchy tree of a config based schematic, normal schematic or layout view? (note you need to use the ?useViewSwitching nil for a layout). Depends on whether you want the window displayed or not as to which makes most sense.
  • vishwas H A
    vishwas H A over 6 years ago in reply to Andrew Beckett
    Thanks for quick reply Andrew, it worked like a charm :)
