  3. convert ircx to ict or emDataFile for Voltus-fi
  • Views 21109
huqy
huqy over 6 years ago
I want to convert ircx file(which is from TSMC,inclued EM Information) to ict or emDataFile for Voltus-fi.
I tried many way, but I can not make it. Can anyone give me some advice?
and I  do not installed QRC.
below is some tools installed my server.
IC617-64b.500.21 is used.
    In general it's best to get the technology data for Voltus-Fi directly from the foundry, as I believe we've moved away from using this utility. If in doubt though, please contact customer support as we can then discuss this in more detail whilst preserving confidentiality.
  • huqy
    huqy over 6 years ago in reply to Andrew Beckett
    Thank you Andrew.
    By the way, I am confused with the usage of ircxtoict  in the QRC tool.
    the usage is diffrent with the document.
    why can not I use ircxtoict like the first usage(in the red box) as document showed.
    thank you very much.
    Andrew Beckett over 6 years ago in reply to huqy
    Well, as I said, the use of ircxtoict has been deprecated; in current versions it's no longer documented because you should (as I said before) be getting the data from the foundry rather than converting it using ircxtoict.
    What you're seeing is that the documentation didn't quite catch up with the tool (the -em_update in older versions used to be optional, then it wasn't any more) - but given that the documentation hasn't been present since at least EXT18.2 (so not in EXT19.1 or QUANTUS20.1 either), that should be a clear indication that I wasn't talking rubbish and you shouldn't be running  it yourself but should get the data directly from the foundry in the right format.
